The zone humidity ratio is the result of the ideal loads flow (as the specified constant humidity ratio), the latent load from people, and the latent addition or removal due to infiltration. The ideal loads system, when controlled to a constant supply humidity ratio (and with no outdoor air) simply takes the zone return air humidity ratio and lowers (or raises) it to match the specified supply humidity ratio.
