Hi Julien, Thanks for your answer. I have already read this section, it's true it indicates the day is fictive. The default range multiplier is fine, but I still need to input the temperature range. I guess one way to do it would be to use my temperature of 30°C as Tmax and then keep the daily temperature range found this same day to find the Tmin. Or to use another daily temperature range, but then how to know what is "representative" for a design day ? I was wondering if people that have actually tried to recreate a design day used that same methodology or did something else ? Thanks, Aurore
