I'm guessing your AirLoopHVAC has a SetpointManager:Scheduled and some outside air, so it still cooling that air.
You can shut off your AirloopHVAC entirely instead, by shutting off the Fan via its Availability Schedule (an alternate way is to use an AvailabilityManager:ScheduledOff but the Fan is easier).
FYI if you still need that outside air - I doubt it since in your case since your building is unoccupied... - you can shut off the Coil:Cooling:DX:SingleSpeed only via its Availability Schedule as well.
