EnergyPlus supports glycol plant loops, and the water-side of Coil:Cooling:Water
is able to handle temperatures below freeezing. But the chilled water coil model has no provisions for frost on the air side, so it's not valid below freezing. For cold-temperature applications, you need to use the refrigeration objects, starting with Refrigeration:AirChiller
