Welcome. There are a few options for handling this - this is my suggestion, once you've created or downloaded your new window Construction:
Leave your original Construction Set intact (I'm assuming that this has been applied to the whole building, on the building-level). For windows that need to be different from the original Construction (included in your Construction Set), go to the Subsurfaces tab in the Spaces section and drag your new window Construction into the Construction field for the appropriate subsurface(s) - as shown by the red arrow.
