The unclear results always a problem for the user of energyplus. The problem you described may have different reasons, so you need to check and show more details in your model. For example: Can you show how you define the cooling coil? checking the sizing:parameter, did you change it to smaller one? or you have other air-conditioning devices in the zone?
