Best practice is to use a WaterHeater:Mixed object. If you read through its documentation, you'll see that EnergyPlus developers suggest setting the tank volume to 0.00379 m3 and setting the heater control type to "modulate". All other inputs should be specified as you would for any other water heater.
Best practice is to use a WaterHeater:Mixed objectWaterHeater:Mixed. object. If you read through its documentation, you'll see that EnergyPlus developers suggest setting the tank volume to 0.00379 m3 and setting the heater control type to "modulate". All other inputs should be specified as you would for any other water heater.
