I looked at your model and you seem to have added an extra port to the Simulator Actor. You shouldn't do that.
The Simulator Actor is expecting one vectorized double input and one vectorized double output. You should use the VectorAssembler in your model to concatenate the outputs of your TSetPoi block to one vectorized output. Please make sure that the types are the same. I see for instance that one of your outputs is of type String. You will need to convert it to a double prior to concatenation. You will then be able to feed the vectorized output to the input of the Simulator Actor.
Note: I haven't run your model to see whether it works but think this to be one mistake which will certainly prevent the model to run properly. I suggest to read the BCVTB manual to correctly set-up the Simulator Actor.
