Is there any recirculated air? My guess is that the HX is conditioning the outdoor air which then mixes with some return air. Use these output variables to see exactly what it happening in the system.
Output:Variable,*,System Node Temperature,hourly; !- HVAC Average [C]
Output:Variable,*,System Node Mass Flow Rate,hourly; !- HVAC Average [kg/s]
Output:Variable,*,System Node Humidity Ratio,hourly; !- HVAC Average [kgWater/kgDryAir]
