click to hide/show revision 1
initial version
This is not the intended application for CentralHeatPumpSystem. Suggest using Chiller:Electric:EIR with heat recovery connections. (You may need to give it a condenser loop that never runs.) Or use HeatPump:WaterToWater:EquationFit:Cooling.
Repeating here suggestions from helpdesk ticket.
Adding this to open issue #5904.
