@Saif that looks like an error in the measure specific to CoilCoolingWaterToAirHeatPumpEquationFit objects. I'll file an issue for this. It was failing on this last line
when OpenStudio::Model::CoilCoolingWaterToAirHeatPumpEquationFit.iddObjectType
    coil = e.to_CoilCoolingWaterToAirHeatPumpEquationFit.get
    coil.isRatedTotalCoolingCapacityAutosized && coil.isRatedSensibleHeatRatioAutosized && coil.isRatedAirFlowRateAutosized ? 'Yes' : 'No'
If you feel comfortable changing line 114 in the measure.rb file you can try changing it to this.
coil.isGrossRatedTotalCoolingCapacityAtSelectedNominalSpeedLevelAutosized && coil.isRatedAirFlowRateAtSelectedNominalSpeedLevelAutosized  && coil.isRatedWaterFlowRateAtSelectedNominalSpeedLevelAutosized ? 'Yes' : 'No'
@Saif that looks like an error in the measure specific to CoilCoolingWaterToAirHeatPumpEquationFit objects. objects, we called invalid methods for this object type. I'll file an issue for this. It was failing on this last line
@Saif that looks like an error in the measure specific to CoilCoolingWaterToAirHeatPumpEquationFit objects, we called invalid methods for this object type. I'll file an issue for this. It was failing on this the last lineline in code below.
