The simplest way to do this is probably using water heaters /water tanks. In OpenStudio, you can set up the plant loops in the usual way, and the setpoint manager(s) will provide for an easy control of loop(s). In OpenStudio, you can also use options for auto-sizing instead of hard-sizing for water heaters, pumps, etc.
