Confirm that the ruleset schedules you tried to drop onto the loads are fractional schedules.
Updated re: ext lighting comment
For exterior lights you can use an Astronomical clock and a schedule. Lights will go in of schedule is on and if astronomical clock says it is dark. The EnergyPlus documentation explains a bit more about the astronomical clock.
