Here is some code that allows you to scale the X-Y dimensions of the building (not the height). Make a new measure and put this into the measure.rb file:
#start the measure
class ScaleBuildingSize < OpenStudio::Ruleset::ModelUserScript
#define the name that a user will see, this method may be deprecated as
#the display name in PAT comes from the name field in measure.xml
def name
return "ScaleBuildingSize"
end
#define the arguments that the user will input
def arguments(model)
args = OpenStudio::Ruleset::OSArgumentVector.new
#make an argument for the X direction scale
x_scale = OpenStudio::Ruleset::OSArgument::makeDoubleArgument("x_scale",true)
x_scale.setDisplayName("X-dimension scale")
x_scale.setDefaultValue(1.0)
args << x_scale
#make an argument for the Y direction scale
y_scale = OpenStudio::Ruleset::OSArgument::makeDoubleArgument("y_scale",true)
y_scale.setDisplayName("Y-dimension scale")
y_scale.setDefaultValue(1.0)
args << y_scale
#make an argument for the Z direction scale
z_scale = OpenStudio::Ruleset::OSArgument::makeDoubleArgument("z_scale",true)
z_scale.setDisplayName("Z-dimension scale")
z_scale.setDefaultValue(1.0)
args << z_scale
return args
end #end the arguments method
#define what happens when the measure is run
def run(model, runner, user_arguments)
super(model, runner, user_arguments)
#use the built-in error checking
if not runner.validateUserArguments(arguments(model), user_arguments)
return false
end
#assign the user inputs to variables
x_scale = runner.getDoubleArgumentValue("x_scale",user_arguments)
y_scale = runner.getDoubleArgumentValue("y_scale",user_arguments)
z_scale = runner.getDoubleArgumentValue("z_scale",user_arguments)
#check the user_name for reasonableness
if x_scale <= 0 or y_scale <= 0 or z_scale <= 0
runner.registerError("X, Y, and Z scale values must all be > 0")
return false
end
#report the initial building area
if model.building.is_initialized
initial_building_area = OpenStudio::convert(model.building.get.floorArea,"m^2","ft^2").get
runner.registerInitialCondition("The building floor area started at #{initial_building_area} ft^2.")
end
model.getPlanarSurfaces.each do |surface|
new_vertices = OpenStudio::Point3dVector.new
surface.vertices.each do |vertex|
new_vertices << OpenStudio::Point3d.new(vertex.x * x_scale, vertex.y * y_scale, vertex.z * z_scale)
end
surface.setVertices(new_vertices)
end
model.getPlanarSurfaceGroups.each do |surface_group|
transformation = surface_group.transformation
translation = transformation.translation
euler_angles = transformation.eulerAngles
new_translation = OpenStudio::Vector3d.new(translation.x * x_scale, translation.y * y_scale, translation.z * z_scale)
#TODO these might be in the wrong order
new_transformation = OpenStudio::createRotation(euler_angles) * OpenStudio::createTranslation(new_translation)
surface_group.setTransformation(new_transformation)
end
#report the final building area
final_building_area = OpenStudio::convert(model.building.get.floorArea,"m^2","ft^2").get
runner.registerFinalCondition("The building floor area ended at #{final_building_area} ft^2.")
end
return true
end #end the run method
end #end the measure
#this allows the measure to be use by the application
ScaleBuildingSize.new.registerWithApplication
Here is some code that allows you to scale the X-Y X-Y-Z dimensions of the building (not the height). building. Make a new measure and put this into the measure.rb file:
#start the measure
def name
end
args << x_scale
args << y_scale
args << z_scale
return args
return false
end
return false
end
end
end
end
end
end
return true
