After checking version, make sure that all the syntax of idf are correct.
I encountered this problem before not because the version issue, but because my idf file has "for: " in the Schedule:Week:Compact objects. This is optionally for EnergyPlus but OpenStudio somehow regards this syntax as a fatal error.
After I removed "for: ", the import is successful.
