If the EMS objects are related to the HVAC systems that you deleted, then you need to delete them in a text editor. As they were influecing HVAC systems no long in your model, there is not impact on the results. The reliability of your results will depend on proper modeling of HVAC systems you decided to use instead.
If the EMS objects are related to the HVAC systems that you deleted, then you need to delete them in a text editor. As they were influecing influencing HVAC systems no long longer in your model, there is not no impact on the results. The reliability of your results will depend on proper modeling of HVAC systems that you decided to use instead.
