If you installed the 1.6.2 installer on your machine it should have automatically updated your SketchUp plugin used. You will have to restart SketchUp to see the changes. To confirm what version you are using go to the "Extensions / OpenStudio / About OpenStudio" menu item. If you don't see 1.6.2 there, let me know and we can look into the issue.
The first thing I would look at is if you have either both 32bit or both 64bit for both SketchUp 2015 and the 1.6.2 isntaller. If you had for example the 64bit SketchUp 2015 but got the 32bit version of OpenStudio 1.6.2 then you would still see the old plugin in SketchUp.
