Your best bet would probably be ZoneHVAC:PackagedTerminalAirConditioner with a Fan:OnOff. You can use this system to provide a set flow rate and temperature for cooling and heating operation, and it will cycle on and off to meet the load in the zone.
This is more complex than ZoneHVAC:IdealLoadsAirSystem because it requires fan, heating coil, cooling coil, and outdoor air mixing objects. I suggest looking at an example file to see how this object is used if you aren't familiar yet with how it works with the other objects.
