I also have noticed this problems with doors where the bottom line coincides (intersects) with parent surface bottom line. The way I solved the problem was to edit the osm file with a text editor slightly increasing height of door bottom line (modifying the Z coordinates).
![]() | 2 | No.2 Revision |
I also have noticed this problems with doors where the bottom line edge coincides (intersects) with parent surface bottom line. edge. The way I solved the problem was to edit the osm file with a text editor editor, slightly increasing height of door bottom line edge (modifying the Z coordinates).coordinates). After reloading the osm file the
lost subsurface now reappears in Sketchup.
![]() | 3 | No.3 Revision |
I also have noticed this problems with doors where the bottom edge coincides (intersects) with parent surface bottom edge. The way I solved the problem was to edit the osm file with a text editor, slightly increasing height of door bottom edge (modifying the Z coordinates). After reloading the osm file the
lost subsurface now reappears in Sketchup.Sketchup. The reason for the problem might be rounding errors
in Sketchup or OpenStudio plug-in.
