You can do this with the AirflowNetwork.
Another simple approach would be to define a ZoneMixing object for each zone and setting the ventilation to zero in your ZoneHVAC:IdealLoadsAirSystem objects. You would then add ZoneExhaust fans (possibly with zero static pressure) to handle the exhaust air flow and make sure your system is air balanced as intended.
