If I understand correctly, you are trying to model two areas of the same building story where the ceilings are at different heights. As an example, let's say that you have a corridor with a ceiling height of 10' above the floor that leads into a foyer with a taller ceiling height of 15' above the same floor. To model this in OpenStudio, use the following process:
If your question is about making different ceiling construction assemblies with different thicknesses, then make two different Construction objects and combine the appropriate Material objects for each layer. Refer to the Constructions section of the OpenStudio documentation for more details.
