I don't have a model to share but this should get you started.
Add ConstructionInternalSource object. The Construction will have to be built layer by layer from Materials.
Assign ConstructionInternalSource to appropriate surface within a Construction Set.
Add ZoneHVACLowTemperatureRadiant system to zone. Select the Radiant Surface Type and connect coils to plant loops. If it's a heating only system, create an "Always Off" schedule and assign it to the cooling coil.
