@Rajani, In the CBECC-Com interface, on the Envelope tab, if you right-click on a BuildingStory object in your model, you should see an option 'View BuildingStory Footprint'. This will create an svg graphics file that shows the spaces, windows, daylit zones, and pri/sec control points in plan view.
These locations match how they get translated to OS/E+. When you run CBECC, it generates an OSM, and if you open that model in SketchUp, you should see the points there as well.
@Rajani, @Ranjani, In the CBECC-Com interface, on the Envelope tab, if you right-click on a BuildingStory object in your model, you should see an option 'View BuildingStory Footprint'. This will create an svg graphics file that shows the spaces, windows, daylit zones, and pri/sec control points in plan view.
