I would write an EnergyPlus measure to edit each surface to edit the surface objects and add the natural vented cavity to the idf when you run your OpenStudio model. The run portion of the measure would probably look something like this:
# create other side conditions model object
sideConditionModel = "
SurfaceProperty:OtherSideConditionsModel,
ScreenCavityModel, ! OtherSideConditionsModel Name
GapConvectionRadiation; ! Type of Modeling used to determine Boundary Conditions
object = OpenStudio::IdfObject::load(sideConditionModel).get
wsObject = workspace.addObject(object)
# get all building surfaces in the starting model
heat_transfer_surfaces = workspace.getObjectsByType("BuildingSurface:Detailed".to_IddObjectType)
surface_names = []
heat_transfer_surfaces.each do |surface|
# change outside boundary condition based on surface construction name
construction_name = surface.getString(2)
if construction_name.match("Ext wall - Insulated metal siding")
surface.setString(4,"OtherSideConditionsModel")
surface.setString(5,"ScreenCavityModel")
end
# put surface name in array
surface_name = surface.getString(0)
surface_names << surface_name
end
naturallyVentedCavity = "
SurfaceProperty:ExteriorNaturalVentedCavity,
Vented Cavity Exterior Surface, ! Name
ScreenCavityModel, ! OtherSideConditionsModel Object Name
0.02, ! Area Fraction of Openings
0.9, ! Thermal Emissivity of Exterior Baffle Material
0.92, ! Solar Absorbtivity of Exterior Baffle
0.05, ! Height scale for bouyancy-driven ventilation
0.05, ! Effective Thickness of Cavity Behind Exterior Baffle
0.97, ! Ratio of Actual surface area to projected surface area
Smooth , ! Roughness of collector
0.1 , ! Cv, Effectiveness for perforations with respect to Wind
0.5 , ! Cd, Discharge Coefficient for Openings with respect to bouyancy-driven flow
#{surface_names.join(",")} ; ! Surface Name
cavity = OpenStudio::IdfObject::load(naturallyVentedCavity).get
wsCavity = workspace.addObject(cavity)
surface_names = []
end
end
