The ChangeBuildingLocation BCL measure is PAT compatible. The problem was a blank weather file used as the default in PAT before the ChangeBuildingLocation measure was applied. Even though the default weather file is replaced by the ChangeBuildingLocation measure, the default weather file must be a valid weather file according to PAT.
