That looks like an error in the input to the WindandStackOpenArea object in the measure caused by a window oriented exactly at 360.0 degrees.
I've edited the measure and re-uploaded it to BCL to set the angle to 0 instead of 360. Re-download the measure and it should work for you.
There is a README associated with the measure on the UnmetHours Github respository.
