See the explanation in the help file under Output > End Use Graph. "Note: For all heat pumps (i.e., air-source, ground-source, or mini-split), the cooling capacity reported is both the heating and cooling capacity of the heat pump itself. Any backup heat (e.g., supplemental heating for an air-source heat pump; electric resistance backup for a mini-split heat pump) will be the reported heating capacity."
