Hello I am experiencing a similar Issue in Eplus 8.9 with the total values of
Zone Ventilation Sensible/Latent HG/HLoss the sum of each component is not equal to the value calculated by eplus in Zone Total Ventilation HG/HL as per image attached It has some kind of concealed elements that is not clearly show up
thanks!
thanks!
It has attached.
Has it some kind of concealed elements that is not clearly show upup?
thanks!
