click to hide/show revision 1
initial version
This example file has two air loops, each serving one zone. It uses two SetpointManager:SingleZone:Cooling objects to set the required supply air temperature for each air loop. Each system has a dry-bulb economizer, direct evaporative cooler, indirect evaporative cooler, DX cooling coil, and chilled water cooling coil. Each component attempts to meet the supply air setpoint and will remain off if the incoming air is already at the setpoint. As noted in the header comments, one of the system has the chilled water coil scheduled off at all times, and the other has the DX coil scheduled off.
