click to hide/show revision 1
initial version
If you want to use evaporative cooling in a single airloop serving more than one zone, or combine it with other equipment, then use one of the evap coolers that can go in an airloop. Each one has slightly different capabilities:
EvaporativeCooler:Direct:CelDekPad
EvaporativeCooler:Direct:ResearchSpecial
EvaporativeCooler:Indirect:CelDekPad
EvaporativeCooler:Indirect:WetCoil
EvaporativeCooler:Indirect:ResearchSpecial
If you want a simple single-zone evap cooler, then use ZoneHVAC:EvaporativeCoolerUnit.
In the example files folder, file ExampleFiles-ObjectsLink.html lists every object type with a few example files that use it.
