You can use the TimeSeries measure to generate 8760 timeseries output of gas and electricity use for each EnergyPlus simulation, but we haven't set up any automated process to facilitate calibrate against monthly billing data.
To date, ResStock calibration has mostly been against annual consumption data from RECS.
You can use the TimeSeries measure to generate 8760 timeseries output of gas and electricity use for each EnergyPlus simulation, simulation and aggregate those to monthly, but we haven't set up any automated process to facilitate calibrate against monthly billing data.
