Hello, the nearest weather file to Hyderabad, Pakistan is Karachi (https://energyplus.net/weather-location/asia_wmo_region_2/PAK//PAK_Karachi.417800_IWEC) if you are looking for specifically Hyderabad, PK, you may to look into to (http://weather.whiteboxtechnologies.com/map-all-typical-year) and probably will need to purchase a TYP weather file. ( use the google map link under the link to browse to HYD, PK location, to find out available weather file type)
Hope this helps.
