There is a public repository for our BESTEST model generation and reporting workflow for EnergyPlus and OpenStudio at https://github.com/NREL/BESTEST-GSR. It contains tests for sections 5.2, 5.3, and 5.4 (excluding 5.2.4 ground coupling).
The zip files from the EnergyPlus 8.9 and OpenStudio 2.5.0 runs are on the repository. This includes the input OSM and IDF files and simulation results.
Lastly the Excel Files summarizing the results are also on the repository.
There is a public repository for our BESTEST model generation and reporting workflow for EnergyPlus and OpenStudio at https://github.com/NREL/BESTEST-GSR. It contains tests for sections 5.2, 5.3, and 5.4 of ASHRAE Standard 140 (excluding 5.2.4 ground coupling).
