You need to make sure that your thermal zones have ideal air loads enabled, otherwise there will not be ideal air loads objects for the ideal loads option measure to act upon.
Run the EnableIdealAirLoadsForAllZones OpenStudio measure before you run the IdealLoadsOptions EnergyPlus measure.
