Specific to OpenStudio, our last major release is 2.6.0, it looks like that is missing from the compatibility matrix, but to install it you just need to install the main OpenStudio installer, and optionally SketchUp 2017. I don't know that you can install it anywhere, but you should have some flexibility. In addition to the OpenStudio components, the install will also install Ruby (contained within the OpenStudio CLI), EnergyPlus, and Radiance for you. You can install SketchUp before or after OpenStudio. If you want to use the command line interface (CLI) you may have to setup the path to OpenStudio.
