To my best understanding reheat energy is wasted energy so I tend to believe that it is the total reheat energy that should be offset from the baseline (but that is just a thought). I believe you can track the reheat energy in the Energy meters section of the E+ report. You can turn on on the following output variables (assuming you use Coil:Heating:Electric):
HVAC,Sum,Heating Coil Heating Energy [J]
HVAC,Average,Heating Coil Heating Rate [W]
HVAC,Sum,Heating Coil Electric Energy [J]
HVAC,Average,Heating Coil Electric Power [W]
You can also create a meter to sum them all to get total Coil:Heating:Electric energy or energy rate.
Then you will have to take out times were Coil:Heating:Electric is used for supliment heating it at all.
To my best understanding reheat energy is wasted energy so I tend to believe that it is the total reheat energy that should be offset from the baseline (but that is just a thought). thought).
| 4 | No.4 Revision |
I believe you can track the reheat energy in the Energy meters section of the E+ report. You can turn on the following output variables (assuming you use Coil:Heating:Electric):
Then you will have to take out times were Coil:Heating:Electric is used for supliment heating it at all.if any.
