Hello Eric, Thank so much for your response.
I changed my reporting to 'detailed' as you suggested and I'm not getting 10-minute intervals but still seeing a similar 'overlap' in the results even at that level of detail:
is it just that I'd need to go even finer grained time-step to see this overlap disappear or is there some other effect that might be causing such a thing to occur?
Everything seems to simulate fine - just trying to understand what is going on with it.
thanks! -Ed
