No, OpenStudio 2.6.0 is not compatible with SketchUp 2018.
No, OpenStudio 2.6.0 is not compatible with SketchUp 2018. 2018, which has an error when opening a SKP file before even creating the OSM. The SKP file below was saved the day before with the surfaces fully enclosed (purple), which disappeared when opened. SketchUp 2018 will also crash intermittently.
No, OpenStudio 2.6.0 is 2.6.0, 2.7.0, and 2.8.0 are not compatible with SketchUp 2018, which has an error when opening a SKP file before even creating the OSM. The SKP file below was saved the day before with the surfaces fully enclosed (purple), which disappeared when opened. SketchUp 2018 will also crash intermittently.
| 4 | No.4 Revision |
No, OpenStudio 2.6.0, 2.7.0, and 2.8.0 are not compatible with SketchUp 2018, which has an error when opening a SKP file before even creating the OSM. The SKP file below was saved the day before with the surfaces fully enclosed (purple), which disappeared when opened. SketchUp 2018 will also crash intermittently.intermittently. See the OpenStudio Version Compatibility Matrix.
| 5 | No.5 Revision |
No, OpenStudio 2.6.0, 2.7.0, and 2.8.0 are not compatible compatible with SketchUp 2018, which has an 2018. I've experienced the error when opening below a SKP file couple times before even creating the OSM. The SKP file below was saved the day before with the surfaces fully enclosed (purple), which disappeared when opened. SketchUp 2018 will also crash intermittently. See the OpenStudio Version Compatibility Matrix. and the SketchUp RuntimeError: bad_weak_ptr issue.
