If you have added People objects to zones, then you will want to double-check your input fields for how occupants exchange heat into the zone:
If you see no latent gains, check if either or both of these inputs is set to 0. If those are both >0, then something else is wrong. In that case, you may have set your occupancy schedule input field to a schedule that's always 0 (people are never in the zone, so they never add heat to the zone).
