what kind of space use type & interior loads do you have in the model? If heavily interior loaded the heat can get trapped inside and the higher WWR ratio (with u-values which are worse than walls, typ) allows that heat to escape. Would/can also shift when the peak load is occurring since it could be a mix of interior/envelope loads too.
