Unfortunately there isn't currently a way to export the PAT analysis HTML files to view them outside of PAT. Although for algorithmic runs you can download a CSV with high level input and output values from the server.
Here is a feature request about this. The data needed to generate an HTML is contained inside of the "out.osw" files for each datapoint in the "localResults" folder. "out.osw" is a JSON file, so if you are comfortable working with JSON files and ruby, you can build up HTML files outside of PAT. If anyone is interested I can share a script that creates a CSV file in this manor. Someone could adapt that to an HTML.
