Sorry there isn't any copy functionality in the HVAC tab of the OpenStudio application. While not ideal someone could write a measure to do this that you could call with "Apply Measures Now". It may be as simple as cloning the water use connection, if the objects are treated as children, or may require more work to also clone the associated objects.
