Based on the information above, the HVAC supply air temperature should always be 14C and the zone air temperature should be between 20 and 24C.
If you want the supply air temperature to vary based on the thermostat requirement, then use a different type of setpoint manager. SetpointManager:SingleZone:* or SetpointManager:Warmest may be what you want, but we need more information about the type of HVAC system to say exactly which one.
