    |  1 |    initial version    |
Try reporting the EMS variable with Timestep frequency instead of hourly. Probably the values are calculated correctly, but they are averaged over one hour for reporting. e.g.: at 05/15  05:00:00 half of the values are 0 and the other half are 5 during that hour, hence the 2.5.
    |  2 |    No.2 Revision    |
Try reporting the EMS variable with Timestep frequency instead of hourly. Probably the values are calculated correctly, but they are averaged over one hour for reporting. e.g.: at 05/15  05:00:00 05:00:00 half of the values are 0 and the other half are 5 during that hour, hence the 2.5.
