The measure fails because of line 80 in this BCL measure "SetOutputTableToIPUnits" where "construction" is misspelled.
    string_objects <<"
    ComponentCost:LineItem,
    #{used_construction_name}_TakeOff,  !-Name
    ,                                   !-Type
    Constuction,                        !-Line Item Type
    #{used_construction_name},          !-Item Name
    ,                                   !-Object End Use Key
    ,                                   !-Cost per Each {$}
    .0000000001;                        !-Cost per Area {$/m2}
It's not relevant to the measure and seems like it was left in from hastily copied measure code.
Lesson - be careful about downloading measures on BCL if they don't have unit tests. Measures under the NREL and UnmetHours organizations are on GitHub and have testing/uploading procedures, so those are more likely to work consistently.
I have access to the organization that posted it, so I'll update the measure and repost to BCL.
    string_objects <<"
    ,                                   !-Type
I have access to the organization that posted it, so I'll update I updated the measure and repost reposted it to BCL. BCL.
The measure fails because of line 80 in this BCL measure "SetOutputTableToIPUnits" where "construction" is misspelled. [EDIT: Measure now fixed on BCL].
    string_objects <<"
    ,                                   !-Type
I have access to the organization that posted it, so I updated the measure and reposted it to BCL.
