EnergyPlus has a built-in way to get the net metered values: Output:Meter,ElectricityNet:Facility;. There are a few other meters you can request, such as ElectricityPurchased, and ElectricitySurplusSold. See the documentation for Meters in EnergyPlus for more details.
In OpenStudio, you can request these meters via a Reporting Measure. Here is what the energyPlusOutputRequests section of the measure.rb file should look like:
  def energyPlusOutputRequests(runner, user_arguments)
    super(runner, user_arguments)
    result = OpenStudio::IdfObjectVector.new
    # use the built-in error checking
    if !runner.validateUserArguments(arguments(), user_arguments)
      return result
    end
    result << OpenStudio::IdfObject.load("Output:Meter,ElectricityNet:Facility;").get
    return result
  end
