OpenStudio models are not backwards-compatible to prior versions. You will need to download and use OpenStudio version 2.5+ to open a version 2.5.0 model.
OpenStudio models are not backwards-compatible to forwards-compatible with prior versions. You will need to download and use OpenStudio version 2.5+ to open a version 2.5.0 model.
