I was able to lode the file from your link to OS 2.5.1 which I use. The name comes out like this:
So I believe that one character in the name of the site in the file is causing the trouble.
You can try to open the file in text editor and delete that char as far as your text editor will save in UTF-8 char set.
Note that on your computer the marked char will be different since you use different encoding than the one I use.
![]() | 2 | No.2 Revision |
this:
