The Wall of your Zone will actually transfer energy by Radiation (which will be governed by the inside wall mean temperature to room mean air temperature difference and some properties of the wall), Convection ( infiltration) and by Conduction (which will be governed by temperature difference between outside to inside and the wall insulation).
If your wall has windows than direct or indirect sun radiation will enter the zone depends on the glass properties.
If your wall has windows than then direct or indirect sun radiation will enter the zone depends on the glass properties.
