click to hide/show revision 1
initial version
OK I Think you hit on a bug. First you have a space that is not assigned to a thermal zone (Space 1 - 1) but that is not the issue. When I tried running your model after deleting Space 1 - 1, on OS 2.5.1 I got that fatal:
 ** Severe  ** CalcCoordinateTransformation: Invalid dot product, surface="FACE 39":
   **   ~~~   **  (  64.008,   8.839,   0.000)
   **   ~~~   **  (  64.008,  42.672,   0.000)
   **   ~~~   **  (  64.008,  51.511,   0.000)
Which means that the model as overlapping vertices in surface Face 39. as you can read. Your original OSW file doesn't have it:
OS:Surface,
  {3c8b133f-2575-4c50-bef6-f23c74d21342}, !- Handle
  Face 39,                                !- Name
  Floor,                                  !- Surface Type
  ,                                       !- Construction Name
  {da039815-96c8-4a86-8c73-761d436691c1}, !- Space Name
  Ground,                                 !- Outside Boundary Condition
  ,                                       !- Outside Boundary Condition Object
  NoSun,                                  !- Sun Exposure
  NoWind,                                 !- Wind Exposure
  ,                                       !- View Factor to Ground
  ,                                       !- Number of Vertices
  76.8096, 51.5112, 0,                    !- X,Y,Z Vertex 1 {m}
  76.8096, 8.8392, 0,                     !- X,Y,Z Vertex 2 {m}
  64.008, 8.8392, 0,                      !- X,Y,Z Vertex 3 {m}
  64.008, 51.5112, 0;                     !- X,Y,Z Vertex 4 {m}
It shows up in the in.osw generated only during simulation :
OS:Surface,
  Face 39,                                !- Name
  64.008, 8.8392, 0,                      !- X,Y,Z Vertex 1 {m}
  64.008, 11.8872, 0,                     !- X,Y,Z Vertex 2 {m}
  64.008, 21.0312, 0,                     !- X,Y,Z Vertex 3 {m}
  64.008, 30.7848, 0,                     !- X,Y,Z Vertex 4 {m}
  64.008, 39.624, 0,                      !- X,Y,Z Vertex 5 {m}
  64.008, 42.672, 0,                      !- X,Y,Z Vertex 6 {m}
  64.008, 51.5112, 0,                     !- X,Y,Z Vertex 7 {m}
  76.8096, 51.5112, 0,                    !- X,Y,Z Vertex 8 {m}
  76.8096, 8.8392, 0;                     !- X,Y,Z Vertex 9 {m}
And then being translated into the in.idf:
BuildingSurface:Detailed,
  Face 39,                                !- Name
  ExtSlabCarpet 4in ClimateZone 1-8,      !- Construction Name
  Corridor 04,                            !- Zone Name
I believe that this bug was already reported here and got to do with the geometry editor.
I was able to work around it when I inserted 4 at the number of vertices of that surface using a text editor. So the object in the OSW file should look like that:
 OS:Surface,
      Face 39,                                !- Name
      4,                                      !- Number of Vertices
